KPFT
Apr 21, 2020Tutor
Replacement Bracket for Orbi OUTDOOR
Is there anyway to get a replacement wall mount bracket for an Orbi Outdoor? Ours broke. I tried calling customer service several months ago and was told there was no way to get one. It just seems crazy there isn't so I thought I'd try here!
On second thought, those tabs are SO SMALL that glue probably won't hold. How about this solution:
Get a piece of plastic at least 1/8" thick that is as wide as the RBS50Y plus 3" (or so) and is as High as the original bracket (or taller, just not shorter). Drill four (or more) mounting holes.
Attach the new bracket to the back of the RBS50Y where the original mounting bracket was supposed to go.
Why plastic? Answer: because it will have little effect on WiFi signals.
See drawing attached.
- KPFTTutor
Thanks. I'd really like Netgear to sell me a repacement bracket.
