mongotz
Feb 01, 2020Aspirant
Replacement for Arris TM1602 Cablevision Modem
I want a modem to replace my Arris TM1602 Cablevision Modem that I pay monthly for. It supplies internet and phone to my home. Using RBR50 and RBR 50Y outdoor mesh system. TY.
tomschmidt
Feb 01, 2020Virtuoso
You need to check your Internet Service Provider for modems that they support. Their web site should list compatible modems, if not then you will need to contact them.
michaelkenward
Feb 02, 2020Guru - Experienced User
Is the ISP has a user group that is also a good place to seek help.
Other users are more likely to be imaginative and resourceful and to "break the rules" and get third party hardware to work.
ISPs are famously ignorant when it comes to the kit that works on their networks. And Netgear doesn't have enough expertise, or the inclination, to test its hardware on every network.
