vbowen600
Jul 30, 2020Follower
Replacement for fried satellite?
I was very happy with my RBS50/AC3000 Orbi, but lightning struck my house and my husband observed the power supply to one satellite glow green then subside - pretty sure it's not supposed to do that!...
CrimpOn
Jul 30, 2020Guru - Experienced User
If you are lucky enough to find one, any regular Orbi satellite will integrate. (Not the "Pro", not the "AX", and not the RBS10 model).
Of course, the RBS50 has the highest performance and most ethernet ports. But, are these qualities actually pertinent?
The serious issue right now appears to be finding a satellite at all.
- CrimpOnJul 30, 2020Guru - Experienced User
This may be a little like "rubbing salt into the wound", but now might be a good time to invest in electrical protection for sensitive electronics. My networking (modem, router, access points, switches), desktop computers, printer, and televisions are all connected to small UPS systems (under $100). The point is not to "keep alive during a power outage", but to avoid the effects of temporary power surges, "on/off" events, etc. At the very least, you might consider power strips with hefty surge protection.
