bjdast
Oct 24, 2020Follower
replacement for the orbi wifi router
Dear friends in the community, What is the best replacement for orbiRBR20 wifi router? My router stopped working but the two sattlelites look ok. Thanks bjdast
Oct 24, 2020Guru - Experienced User
Any of the RBR20, RBR40, RBR50 units would work.
the rbr50 would have the wider backhaul (the rbs20's wouldn't be able to utilize the full bandwidth).
So basically its what would best fit your budget and needs.
