Télépermanence
Mar 22, 2024Aspirant
Replacement of an RBR 50 V2
Good morning, I have this "central" with 2 satellites. The 2 satellites work, but the control unit no longer turns on.... Could you please tell me which model to replace it with so that it continu...
Mar 22, 2024Guru - Experienced User
Did you happen to swap out the power adapter with one from one of the RBS to see if the RBR unit would turn on?
If that fails, then any RBR 20, 30, 40 or 50 series will work with your RBS50. There not sold new anymore so try and find what maybe available on places like, ebay, amazon or shopgoodwill.
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
Good Luck.
Télépermanence
Hello, thank you very much for your response and for your help!
If I understand correctly, it is impossible to find a new device that can take its place? I have to replace everything?
Thank you so much !
Thank you so much !
- FURRYe38Mar 22, 2024Guru - Experienced User
New replacements are no longer sold. If you can find previously used models that work, can keep your RBS50s going. If not, Ya, you'll need to get into some new stuff that's out on the market.
- TélépermanenceMar 25, 2024Aspirant
Hello,
Thank you very much for your answer !
This bothers me a lot, because I sold these devices 4 years ago at a high price and now we have to replace everything, the customer is not going to be happy at all...
- CrimpOnMar 25, 2024Guru - Experienced User
eBay has lots of used RBR50 routers. I bought one (years ago) from eBay to use as a spare and it was fine (still is).
The RBR50 was introduced in 2016 as a WiFi5 product. In the past eight years, WiFi6, WiFi6E, and WiFi7 have come out with the newest smart phones, tablets, laptops, etc. supporting these higher speeds. Not much of a market for WiFi5 devices any more.
If my black and white TV breaks, what are the chances I can find someone selling a new replacement?
(no. I don't have a Black and White TV.)
