Télépermanence
Mar 22, 2024Aspirant
Replacement of an RBR 50 V2
Good morning, I have this "central" with 2 satellites. The 2 satellites work, but the control unit no longer turns on.... Could you please tell me which model to replace it with so that it continu...
Télépermanence
Mar 25, 2024Aspirant
Hello,
Thank you very much for your answer !
This bothers me a lot, because I sold these devices 4 years ago at a high price and now we have to replace everything, the customer is not going to be happy at all...
CrimpOn
Mar 25, 2024Guru - Experienced User
eBay has lots of used RBR50 routers. I bought one (years ago) from eBay to use as a spare and it was fine (still is).
The RBR50 was introduced in 2016 as a WiFi5 product. In the past eight years, WiFi6, WiFi6E, and WiFi7 have come out with the newest smart phones, tablets, laptops, etc. supporting these higher speeds. Not much of a market for WiFi5 devices any more.
If my black and white TV breaks, what are the chances I can find someone selling a new replacement?
(no. I don't have a Black and White TV.)
- FURRYe38Mar 25, 2024Guru - Experienced User
I see about 7 RBR50s on shopgoodwill. 😉
- TélépermanenceMar 25, 2024Aspirantthe problem is that I don't trust this product because we see that there are a number of them that break down from what I see on google.
And the problem is that I installed it just 4 years ago.
But thank you very much for your help!- FURRYe38Mar 25, 2024Guru - Experienced User
Many factors can cause problems with any electronic wifi system. And electronics don't always last forever.
Good Luck.
