LouisZ
Apr 15, 2020Follower
Replacement of RBR 40 router - due to hardware failure -
I have to replace my RBR40 Router part of a 3 satellite configuration. I will call this the original new product install RBK40(Orig) . The RBR40 (orig) router damage was verified by Netgear Support...
Apr 20, 2020Guru - Experienced User
Has a factory reset and setup from scratch been performed since last update?
LouisZ wrote:I have to replace my RBR40 Router part of a 3 satellite configuration. I will call this the original new product install RBK40(Orig) . The RBR40 (orig) router damage was verified by Netgear Support staff. The staff advised me to replace the damaged item, after extensive searching we confirmed that I could not purchase a standalone new RBR40.
I have the following situations
Router replacement and Set up
I found two used RBR40 routers - one a refurbished unit on via Amazon , and a used unit for e-bay. I will call the eBay RBR 40 router unit as RBR40 (e-bay) , the second as RBR40 refurbished RBR40(Refurb)
I noticed that the three satellites have the password for the RBR40 (orig) , does this imply that I need to some how load the new password from RBR40 (e-bay) . I am having difficulties setting up the satellites.
I have RBR40 (e-bay) up and running and we noticed a reduction in performance (area-distance) covered. Is there anyway to check or verified power .
Is there anywhere I can send RBR40 (orig) For diagnostics and potential repair I need to identify the damage and potential source in the house .
