LouisZ
Apr 16, 2020Follower
Replacement of RBR40 Router in RBK44
I have to replace my RBR40 Router part of a 3 satellite configuration. I will call this the original new product install RBK40(Orig) . The RBR40 (orig) router damage was verified by Netgear Support...
Apr 16, 2020Guru - Experienced User
Has a factory reset and setup from scratch on the ebay RBR been performed since you recieved the unit? Same with the one from amazon.
I don't know if NG has any after warranty repair services.
