wairds
Apr 12, 2021Tutor
Replacement Orbi Satellite
I had cause to replace my Orbi Satellite as it had failed. This was replaced under warranty. I was fortunate as the warranty only had 3 weeks to run. When I came to register the replacement satel...
Apr 12, 2021Guru - Experienced User
Would have to agree with CrimpOn
You buy a device with a 1 year warranty. yes it was replaced so in theory the new one should last another year but the warranty isn't transferable.
Similar to a car. Your warranty could be 60K. Even if a part/motor is replaced in the car, it doesn't give you another 60K.
