D18GE's avatar
D18GE
Star
Feb 19, 2020
Replacing Centurylink C3000Z with Orbi router
Has anyone successfully replaced the CenturyLink provided C3000Z router with their Orbi?  If so, what settings did you have to change on the Orbi?  I know you have to input username and password provided by CL but what else was required?
Thanks
  • FURRYe38's avatar
    If your ISP supports PPPoE and user name and PW for the account then this would be needed. Contact your ISP and ask them if this is support and possible. They will be able to help you get the Orbi setup using this information.
    The C3000Z is a modem/router so a modem will still be needed.
    https://www.centurylink.com/home/help/internet/modems-and-routers/zyxel-c3000z.html
    Ask about if this model modem can be bridged.
    3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
    • D18GE's avatar
      D18GE
      Star
      CenturyLink basically told me to ask Netgear how to set up the Orbi.  They did say that while they do not support bridging the C3000Z, they did point me to the instructions on how to do it.  While researching this I found one person who said the modem wasn't required at all but VLAN tagging had to be set for ID 201.  Tried that but no cigar so guess will have to try the bridged approach.
      • FURRYe38's avatar
        First off, The modem or a modem will be needed!!! The Orbi or the Orbi RBR50, RBR40 or RBR20 series do not have built in modems. Only the CBK40 which has a built in cable modem for cable ISPs. You have a DSL modem/router. So you can try the bridge mode and ensure the user name and PW are entered into PPPoE on the Orbi, if needed. Review the bridgeing instructions and go from there, if not, try option #2 of my suggestion.
