BadgerDog
Dec 21, 2019Aspirant
Replacing Home Apple Extreme Router Network with RBK50 AC3000 Tri-Band WiFi
I currently have a hardwired Cat 6 LAN and an Apple Network Extreme router located in our below ground level basement and connected to my Bell Canada DSL Internet Modem. The Apple router connects in...
Dec 21, 2019Guru - Experienced User
Keep the current network running and disable the wifi on Apples router. Then configure the Orbi for AP mode. Connect it to the network as being your upgraded WiFi system. Keeping the apple router network as your main router for the system would be easiest solution.
You can use the same SSID and PW on the Orbi system as what your currently using.
