BadgerDog
Dec 21, 2019Aspirant
Replacing Home Apple Extreme Router Network with RBK50 AC3000 Tri-Band WiFi
I currently have a hardwired Cat 6 LAN and an Apple Network Extreme router located in our below ground level basement and connected to my Bell Canada DSL Internet Modem. The Apple router connects in...
SW_
Dec 29, 2019Prodigy
BadgerDog wrote:For clarity as I'm getting confused.
Main Orbi is set to AP mode.
Main Orbi is connected from one of its own LAN ports to a LAN port on the Apple Router.
As I said Backhaul works fine wirelessly to satellite ORBI.
Can't get hardwired backhaul to work as the instructions say it should because both Orbi's are sharing the same switch. As per Netgear instructions, I even tried plugging the Main Orbi directly into the Linksys 32 port switch shared by the Satelliore Orbi but still doesn't work.
I would assume the instruction refers to how to hook up LAN backhaul, which assumes Orbi WAN port is already connected to ISP modem. Basically, connecting Orbi LAN to existing LAN network might work, but it will end up with other problems. The Orbi WAN port can't be left open or unconnected to ISP modem when in Router Mode or to another router's LAN when in AP mode.
You can verify this by swapping out all Apple routers with Orbi and Satellites in place.
Sorry if this's confusing.
BadgerDog
Dec 29, 2019Aspirant
Hmmm... thanks .... :smileyhappy:
I really don't want to get rid of the main Apple Router connected to the ISP DSL modem.
I just want the Orbi's to provide only my wireless needs throughout the house.
Perhaps I've misunderstood the Netgear FAQ, but it indicates that's possible.
I'll experiment with your suggestion and see if I can get a LAN based backhaul to work your way and come back here.
