williamxx's avatar
williamxx
Follower
Nov 22, 2023
replacing R6220 with SXR30
how do I reconnect devices from R6220
  • michaelkenward's avatar
    michaelkenward
    Tell us more.
    Manuals are always a good place to start.
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Begin with the Quick Start/Installation Guide.
  • plemans's avatar
    If you use the same ssid from the R6220 on the SXR30, it should just auto-connect
