bgmyers
Aug 27, 2020Aspirant
replacing RBK33 with RBK23
I am replacing my RBK33 with RBK23. Will the instalation remove or discard the RBK33 and allow me to load RBK23? Anything I should know or watch out for? Thank you
Mstrbig
Aug 27, 2020Master
bgmyers wrote:I am replacing my RBK33 with RBK23. Will the instalation remove or discard the RBK33 and allow me to load RBK23? Anything I should know or watch out for?
Thank you
Don't quite understand your question.
If installing a new system, reboot the router or device you are connecting to and follow the instrustions for installing a new system.
When replacing the Orbi router with another Orbi router, you would have to configure the router and satellites. But it's a moot point, since you are replacing everythhing.
If the RBK23 system is not new, I would factory reset the router and 2 satellites.
Reset the RBK33, if you are planning on selling it.
- bgmyersAug 27, 2020Aspirant
I recently purchased an Amazon warehouse AC2200 RBK33. I want to replace it with a new AC2200 RBK23. If I understand you,I need to start the installation process with a reboot, the same process I used when I connected the RBK33. Do I need to delete the RBK33 form my iphone app? Anything else I need to be aware of?
- MstrbigAug 27, 2020Master
bgmyers wrote:I recently purchased an Amazon warehouse AC2200 RBK33. I want to replace it with a new AC2200 RBK23. If I understand you,I need to start the installation process with a reboot, the same process I used when I connected the RBK33. Do I need to delete the RBK33 form my iphone app? Anything else I need to be aware of?
Yes the same process as you used with the older Orbi. No
