mark146
Jul 26, 2024Aspirant
Replacing RBR40 with RBR 750
I'm replacing an RBR40 with an RBR750. The PW protocol has changed—my RBR40 didn't require caps, while the 750 requires one cap. I'm changing the network name to avoid making changes on all devic...
- Jul 26, 2024
There's probably a 100% chance I'm confused. I'll monkey around with it more over the weekend and reply. Thank you for pointing that out. I'm an idiot when it comes to this stuff.
Jul 26, 2024Guru - Experienced User
Are you talking about the log in PW? Log in PW requires a Cap
The WIFI SSID PW doesn't require anything. I use all lower case with mine. Been use same SSID name for years.
mark146
- FURRYe38Jul 30, 2024Guru - Experienced User
Any progress on this?
- mark146Jul 30, 2024Aspirant
Yes, thank you, you were correct! I'm sorry I didn't mention this earlier, I appreciate your help!
Glad you got it working. Please mark your thread as solved so others will know. Be sure to save off a back up configuration to file for safe keeping. Saves time if a reset is needed.
Enjoy. 📡
