hearts
Sep 30, 2020Aspirant
rerouting router login 192.168.1.1:80 what is the :80 ?
Everytime I sign in to Router login 192.168.1.1 it seems to automatically be changed to 192.168.1.1:80 (with the :80) is this an legitimate login? Thank you.
hearts
What Orbi model do you have? RBK50
FW version on the Orbi system? it says it is up to date
What browser are you using? this happened on safari as well as chrome. I saw some strange file on chrome and deleted and emptied cache. then seem to work fine while on google chrome. I logged in without getting the :80 . Immediately changed admin PW.
Does this happen in IE11, Edge, Firefox or Opera? Safari. Is it possible another router is accessing modem or orbi router? on another community post someone has said it is a double NAT.
Sep 30, 2020Guru - Experienced User
So what version of FW do you have loaded on the Orbi system? There are a couple of different versions.
No, the CM modem is just a modem only. No built in router here.
