edilks
Jun 17, 2020Aspirant
Reserve fixed IP device on EX2700 with Orbi
I am using an EX2700 to extend my orbi, basically converting a wired device to wifi. I configured the EX2700 with the same base address as Orbi (10.0.0.x). I have the wired device connected to the E...
- Jun 17, 2020
Oh, fudge. When I opened the Orbi LAN Setup, I had already reserved an entry for the laptop using the virtual MAC address, and this is the IP address that it was given. So the answer clearly is, "Yes. Use the virtual MAC address to reserve an IP address for the ethernet device."
Why the device connected to the EX2700 in post #1 (a) did not appear, and (b) could not be access is a matter for analysis.
CrimpOn
Jun 17, 2020Guru - Experienced User
edilks
My attached hardwired ethernet device finally did show up in the orbi device list as expected. The device also showed up in the list when I went to reserve the IP that I assigned. It showed up with the virtual mac address! So I guess that answers the question. I guess the extender creates a new mac address that it exposes to the outside world. Don't really know why... but it all seems to work now! I applied it and it stuck, w/o breaking anything! Thanks for the help.
