w2usf
Apr 02, 2019Tutor
Reset admin password in the SET PASSWORD screen in ADMINISTRATION not working
I know my password and can sucessfully login. However the SET PASSWORD screen does not permit the change When I clink on APPLY nothing happens - no errors messages displayed and must click on cancel ...
Apr 02, 2019Guru - Experienced User
What browser are you using? Try IE11, FF or Opera?
- w2usfApr 02, 2019Tutor
Firmware V2 31.44 just downloaded earlier in the day. Brower is Chrome
- FURRYe38Apr 02, 2019Guru - Experienced User
Thanks for the tip. I have several other browers installed. They are not curative.
It seems unlikly it is a browser problem or that a simple password reset is browser dependant. In any case I see no advisories concerning incompatibility by NetGear.
It seems to be a software flaw ny NetGear is ignoring.
Liklly the cure is a hard rest.
