w2usf
Apr 02, 2019Tutor
Reset admin password in the SET PASSWORD screen in ADMINISTRATION not working
I know my password and can sucessfully login. However the SET PASSWORD screen does not permit the change When I clink on APPLY nothing happens - no errors messages displayed and must click on cancel ...
Apr 02, 2019Guru - Experienced User
What browser are you using? Try IE11, FF or Opera?
w2usf
Apr 02, 2019Tutor
Firmware V2 31.44 just downloaded earlier in the day. Brower is Chrome
- FURRYe38Apr 02, 2019Guru - Experienced User
- w2usfApr 02, 2019Tutor
Thanks for the tip. I have several other browers installed. They are not curative.
It seems unlikly it is a browser problem or that a simple password reset is browser dependant. In any case I see no advisories concerning incompatibility by NetGear.
It seems to be a software flaw ny NetGear is ignoring.
Liklly the cure is a hard rest.
- randomousityApr 02, 2019Luminary
Just to check, you don't have your browsers or a password manager auto-filling the password for you, do you? Like, you think you changed the password, but it was actually overwritten by a saved password, so the password you submitted was really just your current password?
Also, you could try using the Orbi app to change the password if the web form isn't working for you. And, as another thought, some browser settings/add-ons can interfere with things. Privacy settings, cookies, ad blockers, tracking blockers, etc., have all caused issues with submitting forms (generally, not specifically with router configs) for me in the past.
