Profaniter's avatar
Mar 03, 2020
Reset Button not working
okay, so I have decided to reset my Netgear Orbi due to a reason I went through today... I have a pin, paper clip, I held down for 10 seconds, 20 seconds, 30 seconds, even for one minute. I still get...
  • CrimpOn's avatar
    Mar 03, 2020
    Perhaps there is a misunderstanding.  When the end of a paperclip is stuck into the tiny "Reset" hole next to the power plug, the Power LED which is right next to the hole will turn from green to amber and then begin to flash.  The "white light" is on top of the Orbi.  Please look at these instructions: https://www.youtube.com/watch?v=cMw4ePACgc4
