Profaniter
Mar 03, 2020Tutor
Reset Button not working
okay, so I have decided to reset my Netgear Orbi due to a reason I went through today... I have a pin, paper clip, I held down for 10 seconds, 20 seconds, 30 seconds, even for one minute. I still get...
- Mar 03, 2020
Perhaps there is a misunderstanding. When the end of a paperclip is stuck into the tiny "Reset" hole next to the power plug, the Power LED which is right next to the hole will turn from green to amber and then begin to flash. The "white light" is on top of the Orbi. Please look at these instructions: https://www.youtube.com/watch?v=cMw4ePACgc4
CrimpOn
Mar 03, 2020Guru - Experienced User
Profaniter
Mar 03, 2020Tutor
Omg that works! Thank you so much, didn’t know why that video isn’t posted anywhere. I was able to have done it on second try! Much appreciated!
