Profaniter
Mar 03, 2020Tutor
Reset Button not working
okay, so I have decided to reset my Netgear Orbi due to a reason I went through today... I have a pin, paper clip, I held down for 10 seconds, 20 seconds, 30 seconds, even for one minute. I still get...
- Mar 03, 2020
Perhaps there is a misunderstanding. When the end of a paperclip is stuck into the tiny "Reset" hole next to the power plug, the Power LED which is right next to the hole will turn from green to amber and then begin to flash. The "white light" is on top of the Orbi. Please look at these instructions: https://www.youtube.com/watch?v=cMw4ePACgc4
Profaniter
Mar 04, 2020Tutor
CrimpOn wrote:Perhaps there is a misunderstanding. When the end of a paperclip is stuck into the tiny "Reset" hole next to the power plug, the Power LED which is right next to the hole will turn from green to amber and then begin to flash. The "white light" is on top of the Orbi. Please look at these instructions: https://www.youtube.com/watch?v=cMw4ePACgc4
okay... for some reasons, I did see the led blink RED, it wasn't amber color... then it went back to green and the ring flashed white... I gave up and researched, it looks like it's bricked and it's possibly the firmware is corrupted...
Mar 04, 2020Guru - Experienced User
Did you press the reset button in back for 15 seconds then release? Does the top ring LED blink WHITE then slowly pulsate WHITE?
Connect a wired PC to the RBR and see if you can access 192.168.1.1
Try this to see if you can recover the RBR if needed:
https://kb.netgear.com/000059633/How-to-upload-firmware-to-a-NETGEAR-router-using-TFTP-client
Profaniter wrote:okay... for some reasons, I did see the led blink RED, it wasn't amber color... then it went back to green and the ring flashed white... I gave up and researched, it looks like it's bricked and it's possibly the firmware is corrupted...
