mcdad10k
Feb 04, 2020Aspirant
Reset mesh connections?
And, another question. In reviewing my Attached Devices, I noted that my outdoor ORBI satellite, located in my shop, is attached to my router, while the satellite in between my router and the shop is...
CrimpOn
Feb 04, 2020Guru - Experienced User
What appears "optimal" to humans, may not appear so to electronics. That being said, you can try turning off both satellites. Power up the "closer one" and let it set for a while. Then, power up the "far" one and see what happens.
When you look at the Attached Devices web page, how does it describe the two satellite connections, "Good"?
- mcdad10kFeb 04, 2020Aspirant
Good point - and yes, both are good.
CrimpOn wrote:What appears "optimal" to humans, may not appear so to electronics. That being said, you can try turning off both satellites. Power up the "closer one" and let it set for a while. Then, power up the "far" one and see what happens.
- CrimpOnFeb 04, 2020Guru - Experienced User
If there are no performance issues, I would be tempted to move on toward another task. (except "cleaning the garage". THAT will never "rise to the top of my list.")
