Appleuser2000
Apr 10, 2020Guide
Reset satellite auto connects to the router
Is this normal? I reset my satellite to factory settings and it auto connected to my base router without doing any sync-ing, it just magically knew to connect. I thought I didn't reset it correctly, ...
- Apr 10, 2020
If they were bought as a set, I thought they auto-paired. I know I initially had a set of RBK50's and the original router and satellite always auto re-pair but my add-on's always need re-syncing. Not 100% on this though.
Apr 10, 2020Guru - Experienced User
Appleuser2000
Apr 10, 2020Guide
plemans wrote:If they were bought as a set, I thought they auto-paired. I know I initially had a set of RBK50's and the original router and satellite always auto re-pair but my add-on's always need re-syncing. Not 100% on this though.
Yes they are a set. I didn't know that, online guides mention that you have to use the Sync buttons. When I first got it, due to the long reboot time of Netgear routers, it kept glowing with white light ring for some time. I thought this means its not connected and I have to Sync it, when I did it took sometime then it connected. I also do this if the connection drops.
I guess it was just rebooting this whole time, not disconnected. Why do they include a Sync button on the satellite then if it is going to auto sync?
