branty
Aug 16, 2020Follower
reset time
i'm trying to reset my router, how long do i have to hold the reset button in for to get the orange light..
rinthos
Aug 16, 2020Luminary
branty wrote:i'm trying to reset my router, how long do i have to hold the reset button in for to get the orange light..
From your signature you have an Orbi. Power on your Orbi router and wait about 2-3 minutes until it's fully booted.
Then using the paperclip, hold in the reset button for ~30 seconds (it takes only about 10 seconds, but it's ok to hold it longer).
Additionally, there's a great 2 minute video here, with reminders (this will un-pair your satleites, you need to reset them too, etc).
https://kb.netgear.com/31486/How-do-I-reset-my-Orbi-system-to-factory-default-settings
Mstrbig
Aug 16, 2020Master
If it's a stubborn one, which I've run across a few, turn off th Orbi, hold the reset button in and turn the Orbi on. Keep holding the reset button until you see flashing red power light.
