branty
Aug 16, 2020Follower
reset time
i'm trying to reset my router, how long do i have to hold the reset button in for to get the orange light..
Aug 16, 2020Guru - Experienced User
Press the reset button for only 15 seconds then release is recommended for a reset.
branty wrote:i'm trying to reset my router, how long do i have to hold the reset button in for to get the orange light..
- MstrbigAug 16, 2020Master
Actually the textbook instructions are, which sometimes doesn't work:
Using a paper clip or similar object, press and hold the Reset button until the Power LED on your Orbi device blinks amber.
