Shearexpert
Mar 27, 2020Aspirant
Reset wifi password
I recently had some security issues and would like to CHANGE the password and or anything else, on my orbi RBR20 before I reconnect to internet. Please help. I already did the factory reset with a pap...
- Mar 27, 2020
RBRs web page at 192.168.1.1 or orbilogin.com
Mar 27, 2020Guru - Experienced User
Use a wired PC or laptop to connect to the RBRs web page and change the Password there. Under Basic/WIreless settings.
- ShearexpertMar 27, 2020AspirantIn sorry but I'm not sure what you mean RBR's website page. Do I great need to activate the ORBI router? All I've done is plug in and do a factory reset
- FURRYe38Mar 27, 2020Guru - Experienced User
- ShearexpertMar 27, 2020AspirantFURRYe38.. Thank you for your help once again. Much appreciated.
