RobertPBurns
Jan 10, 2020Aspirant
Resetting admin password on Orbi wireless mesh
How do I reset the admin password on my Orbi mesh without doing a factory reset?
CrimpOn
Jan 10, 2020Guru - Experienced User
On the Orbi web interface, the Advanced Tab, Administration, Set Password.
Of course, you have to know the current password to log in and do this.
- RobertPBurnsJan 10, 2020Aspirant
I guess I should have said that I have forgot ten the password and need to reset it. Looks like factory reset is the only way to do it.
- CrimpOnJan 10, 2020Guru - Experienced UserIf you carefully created entries during the setup, when you enter an incorrect password three times, it takes you to Password Recovery. (I have used it.) otherwise, it is "paperclip time"
