RobertPBurns
Jan 10, 2020Aspirant
Resetting admin password on Orbi wireless mesh
How do I reset the admin password on my Orbi mesh without doing a factory reset?
RobertPBurns
I guess I should have said that I have forgot ten the password and need to reset it. Looks like factory reset is the only way to do it.
CrimpOn
Jan 10, 2020Guru - Experienced User
If you carefully created entries during the setup, when you enter an incorrect password three times, it takes you to Password Recovery. (I have used it.) otherwise, it is "paperclip time"
