Gellie
Jul 27, 2019Aspirant
Resetting one of my satellites
Getting spotty service from one of my satellites. Some of my devices are connecting to a further away satellite. I want to try to reset the faulty one. Do I just hold in the reset button for ten seco...
Jul 27, 2019Guru - Experienced User
Press the reset button for 15 seconds the let go. Wait for the top LED to slowly pulsate WHITE. Then hit the synce buttons on the back of the RBR and RBS.
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
- GellieJul 27, 2019Aspirant
Thanks. ~3500 sq ft. I just recently upgraded my Fios speed. Unfortunately they had to relocate the router to the basement. So I now have to orbi router plugged into it. One satellite on the 1st fl and another on the second fl. Some of my devices are connecting to the satellite on the second fl even though they are closer to the 1st fl.
