Ragkzz
Nov 09, 2020Aspirant
Resetting RBK23 satellite
Hello, I recently bought a DC plug adapter for an RBK23 satellite so that I could bring it closer to the signal and get a good one. When I connect the adapter, the Power light flashes green and orange...
Nov 09, 2020Guru - Experienced User
Does the RBS work with the stock adapter?
Be sure you bought the correct AC adapter for the RBS. The voltage and AMPs are most important and should be the same. One can always use an longer extension cord instead of replacing the stock adapter to gain cord length.
- RagkzzNov 09, 2020AspirantHi thanks for the answer, yes it works with the stock adapter. I am not sure if it is the right câble adapter because I couldn’t find the voltage and AMP my RBS need. Could you say me what are they ?
Thanks- FURRYe38Nov 09, 2020Guru - Experienced User
Look at the sticker on the stock adapter, this will have the voltage and AMPs needed.
I would keep using the stock adpater and just get you a long power extension cord.
