Ragkzz
Nov 09, 2020Aspirant
Resetting RBK23 satellite
Hello, I recently bought a DC plug adapter for an RBK23 satellite so that I could bring it closer to the signal and get a good one. When I connect the adapter, the Power light flashes green and orange...
Ragkzz
Hi thanks for the answer, yes it works with the stock adapter. I am not sure if it is the right câble adapter because I couldn’t find the voltage and AMP my RBS need. Could you say me what are they ?
Thanks
Thanks
Nov 09, 2020Guru - Experienced User
Look at the sticker on the stock adapter, this will have the voltage and AMPs needed.
I would keep using the stock adpater and just get you a long power extension cord.
