StephenCG
Nov 12, 2020Aspirant
Restrict DHCP?
Hello Everyone, Thanks for taking the time to read this. I've got a Netgear Orbi Mesh router with one sattelite. Everything was fine until 3 days ago when the cable modem I own was replac...
- Nov 14, 2020
OK, first off, you don't have to be a **bleep**. You made a short answer, being "no, you can't" into this whole big long thing and have been throwing shade for most of your replies.
Second, I'm asking if this device will do something that many other devices do. Just because you don't like the question, doesn't make it the wrong one.
Third, I intentionally left off the make/model of the modem to minimize the "Have you tried doing this?" posts that I didn't want. As if I hadn't tried any of the things y'all would've said to log into the modem to try. The cable modem given to us from Altice One needs the DHCP on and the WiFi on for the DVR's to work. Period. Turning those functions off is not an option.
Lastly, I've managed to solve the issue by setting up VLANs on the Cisco switch so that the only devices getting an IP from the cable modem are the DVR devices.
You can reply if you like, but I'm done with this post, and most likely the community as well.
Good day.
StephenCG
Nov 14, 2020Aspirant
Good day.
antinode
Nov 14, 2020Guru
> [...] You [...] have been throwing shade [...]
_Who_ has been hiding more information?
> [...] I intentionally left off the make/model of the modem [...]
How helpful was that, exactly?
> [...] setting up VLANs on the Cisco switch [...]
Why didn't _I_ think to suggest that? I can be such a dope.
- StephenCGNov 14, 2020Aspirant
antinode wrote:> [...] You [...] have been throwing shade [...]
Hiding information? It's my network and my information. I share what I do/don't like about my network.
VERY. It did, in fact, minimize the questions I didn't need.
Because you didn't know I had a Cisco switch that was capable of VLANs. You were just assuming I was some moron that didn't know anything...
- antinodeNov 14, 2020Guru
> [...] You were just assuming [...]
"assume" and "infer" are spelled differently for a reason.
- StephenCGNov 15, 2020Aspirant
Yes they are. That's why I used the correct one.
