c00labah
Apr 11, 2021Aspirant
Resurrecting my Orbi Satellite from the almost dead (RBS40) - firmware appears to be corrupted
My Orbi RBS40 satellite is 'as new' - it has sat in a cupboard since it was bought. Unfortunately, it appears that the firmware is corrupt. It cannot join the router - persistent purple ri...
Ha_Ku_Na
Apr 11, 2021Luminary
Have you tried this steps?
https://community.netgear.com/t5/Orbi/Solution-to-fix-Orbi-Satellite-flashing-white-forever-failed/m-p/1623284/highlight/true#M39130
c00labah
Apr 16, 2021Aspirant
Thanks very much for your reply. Unfortunately following these steps doesn't work.
I simply can't ping 192.168.1.1 - it tells me 'request timeout'. Not a single ping is successful.
If I soft reset (orange light), the satellite gives me a short burst of 4 successful pings at around 20 seconds after restart at 192.168.1.250, but after that it tells me 'request timeout'.
I can't navigate to 192.168.1.10 (the static IP that I've set), nor can I navigate to 192.168.1.250 (internal server error).
Anything else I can try?
