c00labah
Apr 11, 2021Aspirant
Resurrecting my Orbi Satellite from the almost dead (RBS40) - firmware appears to be corrupted
My Orbi RBS40 satellite is 'as new' - it has sat in a cupboard since it was bought. Unfortunately, it appears that the firmware is corrupt. It cannot join the router - persistent purple ri...
CrimpOn
Apr 11, 2021Guru - Experienced User
c00labah wrote:The satellite is able to be pinged (192.168.1.37), but if I try to navigate to 192.168.1.250, it gives a 500 (internal server error).
Can you open a web browser to http://192.168.1.37 ?
c00labah
Apr 16, 2021Aspirant
No, I can't browse to the static IP I've set. As per my reply above, browsing to 192.168.1.250 returns '500 - internal server error'.
