dstranathan
Aug 17, 2018Apprentice
Returning my CBK40 System
After 3 months of struggles, I am finanly giving up on my CBR40 modem/router (and CBK40 kit). I have had Spectrum technicians out so many times that they have told me they wont help me until I use th...
There any ethernet switches in between the CBR and satellites? If so, Mfr and model# please...
How is you first set up the satellites for wired back haul? You have to set one up at a time via wireless, then connect the lan cable and wait 5 minutes for the the top led on the satellite to turn on BLUE. Then set up a IP address reservation for the satellite.
I also use wired backhaul with my 1 satellite and have no problems with wired back haul. The only issue I see randomly is that when some other device comes online, either new or a reboot on the router, for some reason the DHCP server fails to assign IP addresses correctly and the satellite and some random device on the network conflicts with the same IP address. I have to turn OFF the satellite. Get the other device reconfigured for a IP address reservation. Then turn on the satellite after the IP address reservation is applied and the CBR fully reboots. For some reason this conflict causes a ARM storm on my LAN network and all my switches start blinking rapidly until I stop the conflict. Have never seen this before in any other router system I have.
Other than this, wired back haul is working here for me. I have 3 non managed switches in between the CBR and satellite.
https://www.broadbandbuyer.com/products/18319-hp-j9794a/specifications/
and 2 of http://us.dlink.com/products/business-solutions/5-port-unmanaged-gigabit-switch/
dstranathan
Aug 22, 2018Apprentice
While I do have NETGEAR brand 8-port gigabit unmanaged switches in all my Ethernet-wired rooms, I am currently NOT using any switches at all. I havent needed them yet. They are powered-off. I may need them in the future if I add more game consoles, computers etc.
