justintan
Oct 02, 2021Aspirant
Right sequence to chnage orbi 6 to an AP
Hi Currently I have my RBR850 wifi 6 set up as a router. internet ->Modem -> RBR850-> switch I would like to use another router and I know there is an option in backend browser to change to ...
- Oct 03, 2021
Netgear has set up a community forum specifically for the Orbi AX product. Most of the people who watch that forum are more likely to have experience with Orbi AX and know how to work it better than those of us who follow this "general Orbi" forum. Might be more likely to find someone who has a solution if the question is posted there:
https://community.netgear.com/t5/Orbi-AX/bd-p/en-home-orbi-axThank you.
justintan wrote:
Hi
backend browser to change to AP mode.
But can I know what the best sequence to do this would be?
1. do the backend change to Ap mode first, and then do the physical reconnection.
2. rewire first and then do the change to AP mode.
thanks!
Oct 03, 2021Guru - Experienced User
Thank you.
justintan wrote:
Hi
thanks!
