heller_matthew
Jul 29, 2020Aspirant
Ring & MLB apps not working ...on wifi only
Hello Orbi Experts: I have at least two apps which refuse to work if ( but only if) connected to wifi using apploe IOS devices. Wwweb-based versions of the same apps work fine with same wifi. ...
Jul 30, 2020Guru - Experienced User
What happens if you disable IPv7 on the RBR if it's enabled?
Do you have any Armor or Circle apps enabled on the RBR?
heller_matthew wrote:Hello Orbi Experts:
I have at least two apps which refuse to work if ( but only if) connected to wifi using apploe IOS devices. Wwweb-based versions of the same apps work fine with same wifi. Other wwwebsites working fine. If/when I turn wifi off and use the weak cellular data signal, all works fine with these apps. ANY suggestions for workarounds are appreciated. V/r-Rgds, Matt in the mountains
- heller_matthewJul 30, 2020Aspirant
Hello Furrye38 & @CrimpOn and thanks for sharing your experience & advice:
With Fv2.5.1.16 we show no Armor nor Circle Apps running. I am ignorant how to check if IPv7 is enabled as the word "ipv7" does not ( at least not readily) appear in the "Netgear User Manual" manual I found for the RBR
<< message not allowing URL>>
These weird "not connecting" messages appear with IOS devices on Orci wifi at my house that have apps: Ring and MLB-Audio. ...including an iphone 8 with (i think) latest IOS v 13.6 and an old ipad.
- FURRYe38Jul 30, 2020Guru - Experienced User
Was a typo on my part. Sorry, meant to be IPv6. IPV6 will be under Advanced tab/IPv6.
LOL I presume IPv7 is coming straight away ...as soon as they're done with the magic vaccine($)
IPv6 is DISabled. Unless you coach me not to, I could try to ENable IPv6?
