freesole
Apr 16, 2020Aspirant
Ring Cameras not connecting to Outdoor Orbi (RBS50Y)
Hi All, I seem to be struggling with my newly purchased Ring outdoor cam's and my Orbi system. I have the RBR50 and the RBS50 satellites. The camera's are outdoors and seem to want to connect to ...
freesole
What would you recommend the value be? Is the idea that the lower the radio signal from the router, the more likely it is that the Ring camera will divert to a satellite?
Apr 16, 2020Guru - Experienced User
Try 75% first then see now the camera operates, then try 50%. You can always put the power back.
freesole wrote:What would you recommend the value be? Is the idea that the lower the radio signal from the router, the more likely it is that the Ring camera will divert to a satellite?
