pablohoney
Jul 12, 2020Luminary
Ring Chime Pro not showing in attached devices
Hi, My Ring Chime Pro is no longer showing in the attached devices list even though it is connected to the network and has been given an IP address as per the logs. It MAC is showing in the not con...
CrimpOn
Jul 12, 2020Guru - Experienced User
pablohoney wrote:
My Ring Chime Pro is no longer showing in the attached devices list even though it is connected to the network and has been given an IP address as per the logs. It MAC is showing in the not connected devices list!
Does the Ring Chime Pro appear to function? i.e. if you press the doorbell, does it "chime"?
Can you Live Stream the Ring doorbell?
pablohoney
Yes, it works fine just not showing as attached for some strange reason?
- CrimpOnJul 12, 2020Guru - Experienced User
pablohoney wrote:
Yes, it works fine just not showing as attached for some strange reason?I had a similar experience with my Nest thermostat. "What?", I said. "My thermostat is not Attached, but it works."
It turned out that the Orbi appears to detect devices by noticing data packets to/from them. When some period of time goes by with zero packets, the device disappears.
I did an experiment. Brought up Attached Devices. No Nest. Opened the Nest app on my smartphone and fiddles with the thermostat. Display temperature. Look at settings. etc. Suddenly, there it was. Attached. So, I closed the Nest app and waited. After about five minutes, it was gone again.
My hypothesis is that the Nest opens a connection to the Nest "cloud" and sits waiting for a packet to arrive.
You might conduct a similar experiment. Confirm that the Ring Chime is "not Attached". Then, open the Ring app and do a Live View. See if the Ring Chime suddenly appears.
- pablohoneyJul 12, 2020LuminaryWill do as it is a strange bug as the device does appear in the logs with an IP address and it’s MAC.
Please report what you find.
