MIkeHewitt
Nov 10, 2019Follower
Ring Door Bell/Orbi issues
I have put up with the problem with Live View for two years caused by some issue between my Orbi and my three Ring Doorbell cameras. Works fine except Live View does not work after the doorbells dis...
ekhalil
Nov 10, 2019Master
It seems that you have located the fault to be related to power saving feature in the Ring cameras?
I have both battery and wired security cameras and I have no issues with them as part of my Orbi network.
- For me, issues appear only when the wifi connection is back, for example when the camera connects to the far satellite rather then the near router. Are you sure you have a good coverage around the cameras?
- Another thing to check if you have multiple routers in your network that can cause connectivity issues?
