Orbi
Apr 19, 2018Star
Ring Doorbell 2 and Orbi
Problem: Ring Doorbell 2, Liveview shows black screen or some other error. Solution: Uncheck Enable 20/40 MHz Coexistence. Storyline: I recently bought the Ring Doorbell 2 and spent hours and d...
waynejs
Nov 21, 2018Tutor
Thanks so much for the tip! I just bought an Orbi and I had the exact same problem with two of my Ring Doorbells (my Doorbell Pro was fine). After I unchecked it, I can now use Live View again.
- FURRYe38Nov 23, 2018Guru - Experienced User
Thanks for letting us know. Glad it worked. Enjoy.
