Orbi
Apr 19, 2018Star
Ring Doorbell 2 and Orbi
Problem: Ring Doorbell 2, Liveview shows black screen or some other error. Solution: Uncheck Enable 20/40 MHz Coexistence. Storyline: I recently bought the Ring Doorbell 2 and spent hours and d...
Jan 03, 2019Guru - Experienced User
Thanks for letting us know. Hope this helps others.
Cicloforza wrote:
I too had problems with activating Ring 2 Live View (blank screen or just reverted to previous menu), had tried other solutions with either temporary on no improvement. Today I tried disabling (unchecking) Enable 20/40 Mhz Coexistence and it immediately fixed the problem, hopefully permanently. If this changes, I'll report. Thanks, Orbi Star for your help.
Cicloforza
Jan 07, 2019Guide
Grrrrrr....after changing the Enable 20/40 Mhz Coexistence setting on Orbi about a week ago with good results, the same issue (i.e., Live View takes multiple activations before starting) is now back. Anyone had luck with adding Ring Chime or Ring Chime Pro with resolving this problem?
- waynejsJan 07, 2019Tutor
Yeah, it stopped working for me as well after a day or so. I think it was temporarily fixed because of the router restarting after disabling 20/40 and not be cause of disabling 20/40.
I have a ring doorbell pro (wired), two spotlight cam mounts (wired), two original ring doorbell (battery powered), and one spotlight cam battery (battery powered).
I've noticed that the wired devices are fine but the battery powered devices have issues. Not sure if that's the issue or if it's just coincidence. Perhaps Orbi doesn't like the way the battery powered devices communicate with it.
- CicloforzaJan 07, 2019Guide
I only have the Ring Doorbell 2 and it's hardwired to power, so I don't think it's the battery. Have you tried adding the Ring Chime or Ring Chime Pro? I read on another post that one of those resolved the connection issues with Orbi.
Sorry, maybe a better phrase would be battery enabled device vs. non-battery enabled device.
My Ring Doorbell Pro and Spotlight Cam mounts aren't battery enabled (works). My ring doorbell 1 and spotlight cam batter are battery enabled (works sporadically). This is all speculation on my part though.
I haven't tried Ring Chime or Chime Pro yet. My cameras that are more essential are working fine, so I haven't found the need to get one. I hear that if you call Ring up, depending on the rep, they may send you a free Chime Pro to see if it works better. You may want to try to see if you can get one.
