wegunterjr
Jun 01, 2019Guide
ring doorbell 2 hasn't been able to connect in months RBR50 and 2 satellites
Hardware Version RBR50 Firmware Version V2.3.1.60 When i first got the ring doorbell 2 it was able to connect to my orbi network. Since some update in January/February it has not been abl...
ekhalil
Jun 02, 2019Master
This can either be a radio issue or an IP network issue:
- I think that the Ring Dorrbell 2 uses only 2.4 GHz radio. What 2.4 GHz channel are you using in Orbi?
- Is Orbi working in Router or AP Mode? What type of ISP modem/Router are you using?
wegunterjr
Jun 02, 2019Guide
I am using RBR50,: so it has the main router and two satellites. The channel is 5 for 2.4GHZ.
- FURRYe38Jun 02, 2019Guru - Experienced User
Try setting manual channel 1, 6 or 11 on 2.4Ghz
- ekhalilJun 02, 2019Master
wegunterjr wrote:
I am using RBR50,: so it has the main router and two satellites. The channel is 5 for 2.4GHZ.It can be that you have interference from your neigbours on this channel. Please try choosing another channel.
If you have the possibility, then please make a wifi scan and see which channels are being used by your neigbours and select the least used channel.
Aprart from the Ring Doorbell v2, what other devices do you have connection issues with?
- wegunterjrJun 02, 2019GuideYeah, I did the wifi scan and that's how I landed on 5. Not too crowded out there and my satellites are within 30 feet of each other.
My ring doorbell no longer connects... Seems strange.- FURRYe38Jun 02, 2019Guru - Experienced User
Try manual channel 1, 6 or 11 on 2.4Ghz
