Thekop84
Nov 01, 2018Guide
Ring Doorbell Pro issues with Orbi
Hi guys. I am not gifted with a great it brain I was hoping some here can help me with my issue! I have a ring door bell pro along with an Orbi and one satellite. At first the Ring connected fine w...
Thekop84
Nov 01, 2018Guide
Thanks for the reply guys. I set the channel to lower then 11 but still no luck. I searched the forums and came across this. I forgot to add that I have a chime pro and it couldnt find my orbi network. After doing this my chime pro sees the network. When I tried it on my ring doorbell at first it saw it, it was in green but when It couldnt connect. I tried it again but then the network was again shown in red. Driving me crazy!
Nov 02, 2018Guru - Experienced User
You review this thread?
- Thekop84Nov 02, 2018GuideI have a ring door bell pro. This thread is in relation to the skybell?
- FURRYe38Nov 04, 2018Guru - Experienced User
It is. Something to see if it may work for your device...
- Thekop84Nov 04, 2018GuideNo worries. I will give it a go and see how I go. I called uo Ring and they are going to send me a new one. It might just be a faulty doorbell. Thanks for all your help guys keep you posted :)
