Thekop84
Nov 01, 2018Guide
Ring Doorbell Pro issues with Orbi
Hi guys. I am not gifted with a great it brain I was hoping some here can help me with my issue! I have a ring door bell pro along with an Orbi and one satellite. At first the Ring connected fine w...
BigDGlad
Mar 20, 2019Aspirant
Wouldn't be easier just to seperate the SSID with telenet and assign the Ring Doorbell Pro to the 2.4GHz SSID and put all other devices (Ruko, iphones, ipads, and etc.) to the 5GHz SSID? This way you don't have to mess with the power settings.
By the way what is loT?
Mar 21, 2019Guru - Experienced User
I asked one of the forum users to confirm for me that you can disable the SSID on either radio Under Advanced Tab/Advanced Settings/Wireless Settings. Uncheck the Enable 5Ghz SSID and see if this helps your setup device connect to the 2.4Ghz radio while setting up your IoT.
