Thekop84
Nov 01, 2018Guide
Ring Doorbell Pro issues with Orbi
Hi guys. I am not gifted with a great it brain I was hoping some here can help me with my issue! I have a ring door bell pro along with an Orbi and one satellite. At first the Ring connected fine w...
Thekop84
Mar 26, 2019Guide
Hi guys,
I ended up replacing the Ring Door Bell Pro with a brand new one and touch wood it has been working like a dram now! I have had it set up for over 4 months now without any drop outs. Perhaps it was just a faulty door bell!
BigDGlad
Mar 27, 2019Aspirant
I purchased my Orbi yesterday, set it up as normal and then telneted into it and changed the names on both the 2.4GHz & 5GHz to the names I had on my old router. I then reset the password on both to password on old router and bingo all devices set up on each SSID just like on old router. The Ring doorbell pro came online (2.4GHz) just fine and works as usual. All other devices went to 5GHz as before. Life is good and no dead spots. If you need instructions on how to Telnet, go to YouTube and search Telnet Orbi.
