buzzoff
Jul 14, 2023Luminary
Ring Indoor WiFi Cam Crashes Orbi Mesh Network
I have an Orbi Mesh (RBR40 & 2-RBR20s). I have had an original Ring stickup cam that works fine with my network but just bought 2 Ring gen 2 indoor cams. Hooked up the first one fine and even worked ...
- Jul 21, 2023
Installed 2nd cam and worked fine. Tried 1st cam again and had problems. After multiple factory resets I was able to finally get both cams working. Sounds like I have a problem with the first cam but obviously able to close this issue.
Jul 14, 2023Guru - Experienced User
I'd contact the Mfr the camera and ask them for help and information regarding there product. IF this is the only device causing then, they may have more information.
- buzzoffJul 14, 2023Luminary
Thanks, you have helped me again. I actually posted on their support page as well but did Netgear as well in case someone has run into the same issue.
- plemansJul 14, 2023Guru - Experienced User
do both cameras cause the issue or only 1 of them?
I don't have the original (gen1?) stickup cam installed right now as I had to do a factory reset on it and just haven't finished reinstalling. However, this one works fine for the last 4 years. Then Gen2, the new one that I installed is the alleged culprit. Based on my troubleshooting the issues point to the Gen2 indoor cam and seems repeatable.
