buzzoff
Jul 14, 2023Luminary
Ring Indoor WiFi Cam Crashes Orbi Mesh Network
I have an Orbi Mesh (RBR40 & 2-RBR20s). I have had an original Ring stickup cam that works fine with my network but just bought 2 Ring gen 2 indoor cams. Hooked up the first one fine and even worked ...
- Jul 21, 2023
Installed 2nd cam and worked fine. Tried 1st cam again and had problems. After multiple factory resets I was able to finally get both cams working. Sounds like I have a problem with the first cam but obviously able to close this issue.
Jul 14, 2023Guru - Experienced User
sorry, in your post I thought you bought 2x of the gen 2 cameras. If both had the same issue or if it was specific to one. Maybe it was a hardware problem with the device
buzzoff
Sorry back at ya :). Actually did buy 2, Prime special, but only installed 1 to start. I like to add things slowly and test and glad I did.
- buzzoffJul 21, 2023Luminary
- plemansJul 21, 2023Guru - Experienced UserGlad you got it figured out!
