WS-010
Sep 23, 2022Guide
Ring led on RBR50
Hi, I have a RBR50 and 3 satellites. I have a hardware firewall in front of the RBR50 and the RBR50 in AP modus. The network cable is not in the routerport, but in one of the switch ports. Al...
WS-010
Sep 23, 2022Guide
Thanks, but unfortunally the satellites won't connect anymore, even after a reset. I have resetted the satellites as well, this will not bring them back up again.
Put the cable back into the switch and connected the satellites again and that's working fine.
I will get some tape and put it over the ring led 😞
KevinLiT
Sep 23, 2022NETGEAR Moderator
Hello WS-010,
Welcome to the NETGEAR Community!
I understand that you have a red light showing on your RBR50. To resolve this issue please connect the ethernet cable from your switch to the WAN port on your RBR50. It is the port in yellow with the text "internet". After you connect your RBR50 to the switch verify that you are able to access the internet from a device connected to your RBR50. Then from your Orbi app navigate to Menus ( on the top-left) > ADD SATELLITE. Then connect your additional satellites to your RBR50.
Best,
Kevin
Community Team
- WS-010Sep 24, 2022Guide
Thanks, I know that I can solve the red ring led issue with the WAN port, but 2 of the 3 satellites are unable to connect. They are all on the same hardware etc.
So restored my old setup and that's working again and I leave it to this. Thanks for the help.
